Machine Vision
comment fonctionne imaq read barcode
I use Imaq read EAN13 and i will know how to function this VI.
(2,941 Views)
For information on this function you may want to check the example program shipped with LabVIEW and IMAQ Vision. You can find it in this directory:
C:\Program Files\National Instruments\LabVIEW 6.1\examples\Vision\3. Applications\Barcode Example.vi
Also you may want to drop the Barcode Reader VI into the block diagram and right-click over it, select Help. If this does not clarifies the question you might have please post the details of it.
Good luck!
Nestor.
Nestor
(2,941 Views)
