Machine Vision
compact vision flash disk problems
I�ve got writing problems with the Compact Vision Module. It is not possible to write to the module�s flash disk.
Using a ftp browser it is impossible to create a new directory, Using LV it is not possible to write a file (generic file IO error) and Vision builder is not able to write scripts to the remote target�
It all has work before.
Does anyone have experience with this? Or good advice?
Kind regards,
Jonas
(3,235 Views)
Try reinstalling all the software on the CVS - this should clear everything up. If that doesn't work, I would phone NI at www.ni.com/ask for more detailed help.
-Julie
(3,235 Views)
