Machine Vision
compute depth image vision
I want to adjust the example compute depth image.vi with my own pictures. To check if this is possible with the camera and setup I allready got. If this works  I want to create my own VI. So far I get random depth images and I can't see what I'm doing wrong. I just follow the same as the example but it doesn't work. Can someone help me?
Kind regards,
Piet
(5,568 Views)
Hello Piet,
Without actual code and examples pictures my first guess would be that it goes wrong during the calibration process.
Which type of images are you using for the calibration stage?
Can you share your code and the used images?
PS: It's been a while since I have tested this example, but if you can share the code + example pictures, then I can do my best to assist you.
Kind Regards,
Thierry C - CLA, CTA - Senior R&D Engineer (Former Support Engineer) - National Instruments
If someone helped you, let them know. Mark as solved and/or give a kudo. 😉
(5,548 Views)
Hello ThiCop,
I've put the code and images in a Diepte bepalen.rar
I couldn't put the .rar file as attachment so I put it on wetransfer:
http://we.tl/thn5sIJyFs
You can download it untill 11 April, 2014.
Kind regards,
Piet
(5,537 Views)
