Machine Vision
concentric rake
Hi to everybody,I`m a newby with labview and the module vision...
I have to use concentric rake on a frame captured on a video, but it stops with this error:
Error -1074395720 occurred at IMAQ Concentric Rake
  Invalid ROI.
Possible reason(s):
IMAQ Vision:  (Hex 0xBFF605B8) Invalid ROI
I`m not able to find a way to input a correct ROIdescriptor I think.....
thanks for the help
Message 1 of 9
(6,785 Views)
Have you tried this?
Message 2 of 9
(6,776 Views)
yes I tried it but it gives me the same error...
Message 3 of 9
(6,744 Views)
could be the problem on the output concentric rake connection?
how can I diplay the edge on the image?
thanks
Message 4 of 9
(6,743 Views)
mat84 -
From the error you mentioned it sounds like either Concentric Rake is getting either an invalid or wrong type of ROI.  Can you post your code or a screenshot of your diagram so we can take a look?
Thanks!
Greg Stoll
Vision R&D
Greg Stoll
LabVIEW R&D
Message 5 of 9
(6,724 Views)
this is the block diagram.......I think there are a lot of mistake because is my 7th day with LABview:-)
thanks a lot!
Mattia
Message 6 of 9
(6,713 Views)
Mattia -
Can you put a probe on the the output of IMAQ WindGetROI to see what ROI is being passed to IMAQ Concentric Rake?
My guess is that there's no ROI on the image window and that's why IMAQ Concentric Rake is returning an error.  You may have to loop and wait until there's actually an ROI on the window before calling IMAQ Concentric Rake.  Another alternative would be to call IMAQ Construct ROI (to let the user select an ROI and click "OK") to get the ROI.
I'm more used to writing code using the Image Display Control instead of the Wind* functions, so hopefully one of these suggestions will work 🙂
Greg Stoll
Vision R&D
Greg Stoll
LabVIEW R&D
Message 7 of 9
(6,707 Views)
Greg-
thanks to reply. I tried to modify the block diagram but I have always the same error
and looking the probe it seems that the rectangle is correct
Message 8 of 9
(6,695 Views)
Mattia -
Whoops - my mistake!  IMAQ Concentric Rake only works on ROIs that are an annulus.  If you want to do a Rake-type operation on a rectangle use IMAQ Rake instead.
Greg Stoll
Vision R&D
Greg Stoll
LabVIEW R&D
Message 9 of 9
(6,689 Views)
