Machine Vision
configure imaq
Thank you,
I have another question, concerning the 6025e board.
I'm afraid that if I sample a pixel by 1 read only on the analog video signal, there would be noise and the quality of the image would be low. I think I've read that this board is able to use functions of dithering and averaging, in order to liniarize and lower the noise of the signal.
How can I enable these functions ?
Message 21 of 28
(2,240 Views)
The PCI-6025E does have the dithering and averaging capability.  See the link below for how to access this feature -- I wasn't sure whether you are using DAQmx or Traditional DAQ functions, but the link contains the steps for both.  That should cover your questions!  Let us know if there's anything else.
Enable Dithering (both Traditional NI-DAQ and DAQmx):
http://digital.ni.com/public.nsf/websearch/3C4A8E88757431AD862565150055CA7D?OpenDocument
Erik Fogleman
Message 22 of 28
(2,218 Views)
Hello MarcoPolo5,
I have now tried to run the vi that you have sent, having the Vision Module installed, but Labview does not recognize the function, called "Convert Image.vi", could you please help me with this ?
Can I use some other function in stead ?
Thank you.
Michael.
Message 23 of 28
(2,301 Views)
we are now doing almost the same thing asyou ,CLSM 。 we also are using the pci1410 to collect the singal of thePMT。 can you give some detail about how to configue the 1410 when using pixel clock ,hsync ,vsync. thanks a lot .
Message Edited by Support on 03-24-2010 08:53 AM
Message 24 of 28
(1,761 Views)
You have just dug a 5 year old thread. Giving email address in a public forum will make your inbox fill with spam. Report to moderator and ask them to remove the email id.
Message 25 of 28
(1,744 Views)
Message 26 of 28
(1,742 Views)
we are making a clsm.it will scanner 4000lines in 1sec, and 512 pixels in a line. the pixel clock =4000*512; and it give out hsync and vsync. we now wanting to use the PCI 1410 to meet the request.
when working in external lock mode ,will it be possible to collect 4000 lines/s and the pictures is clear.
Message 27 of 28
(1,719 Views)
can the VCODivider be other other number than 2,4,8,16, the pixel clockof ours can not meet the request you gave in the PCI-1410 access non-standard camera or video source configuration.
What shuld we do , can we choose some other kind of frame grabber. may you please give some advoce about our design .
thanks
Message 28 of 28
(1,718 Views)
