Machine Vision
connect reference for twain labview
how to set Twain reference
i have a scanner and need to control it via labview using twain driver ..the issue in how to set the reference in the code
any help plz
(4,790 Views)
could you send code in lv 2014 ?
(4,776 Views)
(4,773 Views)
if you install driver well and also if you have related active x ( i do not have it )
in active x box you can select a scanner for creating reference
here is some site that may help you
http://www.alliancevision.eu/products/softwares-drivers/drivers/vi-labview-library-for-twain-protoco...
http://www.ciansoft.com/samples/default.asp
(4,746 Views)
thnx alot
(4,723 Views)
your wellcome
(4,718 Views)
