Machine Vision
connect zavio ip camera to sbrio 9632
HI all
iam trying to connect my zavio f 1105 camera to sbrio-9632 without using ip camera adapter to avoid using labtop every time i use the project
the camera doesn`t show in ni-max
can i have some help
(2,874 Views)
We don't support that brand of IP cameras, so you will not be able to see it in MAX if you just plug it in directly to the sbRIO.  In order to be able to use that camera with our software, you have to use your adapter.
The following links have more information:
https://knowledge.ni.com/KnowledgeArticleDetails?id=kA00Z000000P6COSA0&l=en-US
https://knowledge.ni.com/KnowledgeArticleDetails?id=kA03q000000x4IqCAI&l=en-US#toc3
I'm assuming your adapter is converting the IP camera into a DirectShow compatible device, which is why you are able to use it on your laptop.
(2,835 Views)
