Machine Vision
conversion of OCR string into text file
Hello everyone
I have tried to convert the string from an OCR to a text file. but it is showing no results please check it out and help me
I have attached the vi
(3,801 Views)
Set your code aside for the moment, and run the NI OCR Training Interface, using the images that you are trying to work with.  This will give you a better idea of how to use the teach VI's, and get better results.
It would help assist you if you post some of the images you are using.
Machine Vision, Robotics, Embedded Systems, Surveillance
www.movimed.com - Custom Imaging Solutions
(3,706 Views)
