Machine Vision
converting camera file from IMAQ 1408 to 1409
I have a custom camera file for use with a Jai CV-M10 camera and a 1408 (external lock). It's based on the standard PAL-file.
I'm upgrading the system with an IMAQ 1409. This card won't accept the camera file. I've looked into the structure of both file formats, and I am unable to adapt the standard PAL-file for the 1409 with the necessery modifications.
(2,933 Views)
There is a separate camera file that ships with NI-IMAQ for PAL signals on the IMAQ 1409. It is called PAL(1409).icd and is located in the NI-IMAQ\Data directory. Try loading this camera file and using it in external lock mode with your camera. Hope this helps.
Jack Arnold
Application Engineer
(2,933 Views)
