01-18-2011 10:14 AM
Hi ;
I am using Labview 2010.
My question is related with IMAQ Count Objects 2.vi
i have track some light sources.However i realised that number(order) of detected object is not stable.
My question is how does this vi label detected objects?Is the brightest one going to be number 0 or the biggest one going to be number 0 ?
What is the procedure of labeling?
Baris Togrul
01-19-2011 09:47 PM
Hey Baris,
Check out this devzone for more detail on Counting Particles or Cells Using IMAQ Vision.
I believe that IMAQ Count Objects 2 VI inputs specify 0 for bright objects and 1 for dark objects.
Hope this helps,
A. Zaatari
01-19-2011 10:06 PM
Brightness and size do not matter at all. When counting objects, IMAQ starts at the upper left corner of the image and scans left to right, then moves from top to bottom. Objects are numbered in the order it encounters them.
Bruce
01-20-2011 12:19 PM
Great! it solved all my problems.
Thanks a lot.
