Machine Vision
create a cumulative histogram, accumulages Histogram
Dear Forum,
How can I create an accumulated histogram from a sequence of images (100) with different exposures?
need help Smiley Embarassed
(2,634 Views)
for this one it is better to change your image into array and try to create your histo function by tools that are exist in mathematical toolkit
(2,602 Views)
Have you looked at the IMAQdx "Low-level Ring Rolling Average" example? That one does a rolling average of N images. You could probably modify it easily to do some operation on the last 100 images.
Note that if you don't want to do it "live", then you can just do a fixed sequence and don't need the complexity of this code.
(2,592 Views)
