Machine Vision
custom interface cannot have dependencies
Hello all,
         I'm trying to program a custom inferace for VBAI using VI. In the VI I'm trying to plot a histogram. However as soon as I provide the path for the VI under inspection interface configuration in VBAI it throws an exception " custom interface cannot have dependencies such as sub VI... ". If I take out the histogram everything works fine. Please provide me inputs as to if there is any work around to display the histogram on the interface.
thanks.
(3,793 Views)
Vision Builder AI cannot import VIs that have dependencies, such as sub VIs, DLL calls, or control type definitions.
see here
(3,782 Views)
You can check out the example here that illustrates how to calculate histograms for your Custom UI without needing dependencies (i.e. calculate the histogram yourself) Example 2 - Statistics is what you want. http://zone.ni.com/devzone/cda/epd/p/id/5734?submitted=yes  Hope this helps, Brad
(3,772 Views)
