Machine Vision
defects inspection of Piece casting.
hello
i have attached a photo of cilander that casting.
i want to detect defects on it with labview vision
im new to image proccessing please help me to start.
(5,257 Views)
First illumination is not even. The sharpness of the image can be improved. By defect do you mean the irregular circular hole?
(5,248 Views)
can you post the image of a good component too?
(5,248 Views)
thanks for answer.
for 1st comment i agree with you...
(5,241 Views)
please explain whether the irregular (sharp edges) hole is what needs to be differentiated
(5,228 Views)
this test has to level
1st is about holes. in 1st picture (1.jpg) left side hole crooked but right side hole is good in 2.jpg both of holes are good. we must 1st check holes that thay are fit to circule shape.
2nd  is about surface. some time we have no good casting like a new photo(3.jpg) that i have attached and the surface of product opaque(not a sleek surface).
thanks for your answers.
(5,212 Views)
