Machine Vision
display Image close callback
I want to execute some code when a user close an imaq display window. Is there a way to attach a callback to this type of window under labwindowsCVI.
ArnO
(3,198 Views)
If you have IMAQ Vision then you can use the imaqGetLastEvent method, which returns the last event that the user performed on an image window. One of the parameters for this method is WindowEventType, which you can specify as IMAQ_CLOSE_EVENT to determine if a user closed a window.
I hope this helps. Best wishes!
Dawna P.
(3,198 Views)
