Machine Vision
draw more than 1 line in Convertline to ROI
is it possilbe to draw more than just 1 line in the IMAQ COVERT LINE TO ROI vi?
Krispiekream
(3,549 Views)
These are the line points which you need to feed
Line specifies the coordinates of the line.
Start X specifies the x-coordinate of the beginning point of the line.
Start Y specifies the y-coordinate of the beginning point of the line.
End X specifies the x-coordinate of the end point of the line.
End Y specifies the y-coordinate of the end point of the line.
(3,535 Views)
Yeah, those are the points I need.
But is it possible for me to draw 2 lines?
1 line = start(x1,y1) to end(x2,y2)
thats 4 values to the line ROI.
is it possible to do
2 lines?
line1start(x1,y1) to line1end(x2,y2)
line2start(x3,y3) to line2end(x4,y4)
I want to draw vertial and horizontal lines on the REGION of INTEREST.
normally we can draw 1 line online, or 1 oval, 1 rectangle, 1 half circle.
I want to draw 1 oval and 2 lines on the REGION of INTEREST. is that possible??
Krispiekream
(3,520 Views)
Are you simply trying to first take a region of interest and then draw two lines in the region of interest? Or are you trying to draw two lines and then have that be converted into a region of interest?
-Zach
(3,506 Views)
