Machine Vision
draw pattern matches position
I would like to draw a red rectagle assigning the pattern matches of an object. I made it using draw pattern matches position.vi. During my searching procedure draw pattern matches position.vi is opened and closed continuously. How to stop it? I would like only to track the object drawing a red rectagle without starting and closing draw pattern matches position.vi.
Regards
(6,197 Views)
try replacing the overlay with the one provided in the attachment.
P.S.: I know it's not any of my business, but you should take some time to clean up/optimize  the code 🙂
K
https://decibel.ni.com/content/blogs/kl3m3n
"Kudos: Users may give one another Kudos on the forums for posts that they found particularly helpful or insightful."
(6,170 Views)
