Machine Vision
easy way to post code images using power point
By the way, I found an easy way to post screen shots of vi's using power point.
Do the Alt+Print Screen thing on the Vi frame you want to post.
Paste it into a blank power point slide.
Edit it using the clip and other picture tools in power point
Right click the image when you like what you see and select Save as Picture
It is saved as a png file.
Put it somewhere, and then browse to it when you get to the add attachments.
Helps when you are talking about "programming" in meetings too.
Hope that helps.
(3,676 Views)
There is  a much better way to do it : download Code Capture Tool an utility developped using LabVIEW, specifically for this purpose !
Chilly Charly    (aka CC)
(3,666 Views)
Right...I think I tried to do that but it took a bunch of download...install stuff
I already have power point...it too is cut and paste.
(3,662 Views)
