Machine Vision
error -1074360317 occurred at an unidentified location.
I am trying to run a vision application from the exe file.  i get the following error.
Can someone help me out with this?
Error -1074360317 occurred at an unidentified location.
Possible reason(s):
NI-IMAQdx: (Hex0XBFF69003)  invalid pointer
Note: I am using an IEEE - 1394 camera for image acquisition with 2009 VDM.
Vision acquisition software 8.2
VDM 2009
thanks and regards,
Visswanathan
(3,975 Views)
Be sure to check whether this is working in the development environment.
If it's, then make sure that you are using drivers that are newer than the development environment you have used. So, if you have developed with VDM 2009, then make sure you have the Vision Runtime for that version and also the drivers that are later than that version.
Adnan Zafar
Certified LabVIEW Architect
Coleman Technologies
(3,965 Views)
thanks for the reply.
I am running the exe in the same pc in which i am running the code. The code is running without problem. I get this error only when i run the exe file.
I have developed the exe in another pc. Should i use higher versions of the drivers when i develop the exe or in the target pc?
can you specify the driver softwares? thanks for the support again.
regards,
Visswanathan
(3,956 Views)
