Machine Vision
error -1074396070
Howdy all!
I am currently trying to use a camera to create a video written to a flash drive. Both the camera and flash drive are connected to a myRIO, and both work with the myRIO. I have as of yet been completely unsuccessful in creating anything at all.
I created my VI using the example Grab and Save to AVI with my own alteration. To the best of my understanding, I believe my code works, but I can't see what the problem might be. After a while, I ran the program with Highlight Execution active and realized an error occurs after the IMAQ AVI2 Create function: error -1074396070. It simply states that "IMAQ Vision:  Unsupported function."
Any help would be greatly appreciated!
Thanks!
-Aggieimperator
(5,175 Views)
Accepted by topic author aggieimperator
I'm not sure exactly, can you try saving file to your local disk, instead of flash and try?
-Also check the codec you're trying to give.
uday
(5,149 Views)
Thanks for the suggestion! It worked when i saved it to the local disk, but the final project this goes with will ultimately have more data saved than space is available on the myRIO.
Well, that's a problem for another day. For what I need now, this'll do.
Thank you very much!
-Aggieimperator
(5,140 Views)
