Machine Vision
error 1074396120 "not an image" when using extractcolorplanes
When I use IMAQ ExtractColorPlanes I get the error "not an image", while the image is a normal *.bmp file. (The image used is an image from file). If I use IMAQ ExtractSingleColorPlane than I receive no error. But when I use multiple IMAQ ExtractSingleColorPlane VI's I recieve the error 1074396080 "invalid image type".
(3,476 Views)
This problem also had to do with the IMAQ Create VI. For every colorplane you have to use an IMAQ Create VI.
(3,475 Views)
