Machine Vision
error when opening vision assistant
Hi
I can open vision assistant in tools Menu and there is no problem and it works fine.
But When I want to place vision assistant in block diagram , i'll encounter This error : "Error writing the vision assistant script to file"
Please help me to solve this problem.
My labview version is 2016/32bit
(3,541 Views)
Does this error pop up when you place the Vision Assistant VI on the block diagram, when you click Finish, or somewhere in between?
I don't see it in the screen shot, but did you notice any error number associated with the error?
Does this occur if you perform only a single line profile profile processing function?
Does it occur every time?
I didn't find anything on that error message with a quick search and haven't run into it before. Please answer the above questions and provide any additional context you have and I will see if I can find you an answer.
Have a great day,
Aaron Douglass
(3,491 Views)
I have same problem
did you solve it?
(3,223 Views)
