Error -1074397150 occured when running snapVI with a 10bits Dalsa2M30 camera, using LV 7.0 (inputs : 16bits, channel 0). Block Diagram is in attachment. However, image is visible when using MAX.
You must change the "Async?" control on the imgSessionAcquire.vi to False. This vi can be found inside the Snap vi: Open the Snap vi>>Open the IMAQ Start vi>>Change the Boolean input to imgSessionAcquire to False. Best Luck TN
