Machine Vision
external trigger for two camera with frame grabber
I already change the image name with different name for each camera, but the result is still the same Smiley Sad
Message 11 of 12
(865 Views)
We don't see any reason why your set up is not working, If you send two separate trigger signals from your DAQ card, do you see any different behavior?
Zach C.
Field Engineer
Greater Los Angeles
Message 12 of 12
(852 Views)
