Machine Vision
extract contour binary image
Could someone help me please? The Vi and the image are attached below.
(4,080 Views)
Hi Giansorr,
thank you for your post on NI forum. In order to perform a Contour Analysis, you can try to analyze some examples you can find at the following path:
<LabVIEW>\examples\Vision\2. Functions\Contour Analysis
The contour algorithm works fine if the image you are going to analyze has wel defined contours.
You can try to run the above examples with your .png image.
Have a nice work.
Claudio Cupini
NI ITALY
Applications Engineering Dept.
(4,059 Views)
