Machine Vision
extract highlighted image
I have a program for pattern matching and the patterns found on the original image are highlighted as seen in attached screenshot. Does anyone know how can I extract/save the final image with highlighted rectangles in it? I have the pixel values beside it but when I save the image it saves only the image and there are no rectangles that can be seen in attached screenshot.
(1,884 Views)
You can merge the overlay into the image and then save it.
Make sure that you create a new colour image to merge it into
Mike
(1,851 Views)
