Machine Vision
eyeball tracking
Hi... I wanna to track only the eyeball movements. I tried with this algorithm...but it doesn't correct all times... can anyone help me....pls soon...
Message 1 of 9
(6,786 Views)
in my opinion, it is very difficult to achieve what you want with pattern matching. You would need to have a really roboust setup.
You can try:
https://decibel.ni.com/content/blogs/kl3m3n/2014/02/24/real-time-iris-detection-in-labview-using-ope...
K
"Kudos: Users may give one another Kudos on the forums for posts that they found particularly helpful or insightful."
Message 2 of 9
(6,770 Views)
its really big one.... thanks for ur help....but it doesn't worked in my system.....
Message 3 of 9
(6,766 Views)
are you talking about the example from the link I posted or about the code you have provided?
The exemple from the link first detects the face and then inside the face region of interest, also the eyes. The pupils are detected using a algorithm from the paper which is also cited. You would need to setup OpenCV (it's open-source).
Also, you could check online for papers regarding the iris detection algorithm.
K
Message 4 of 9
(6,763 Views)
Sir, without open cv, is not possible..?
Message 5 of 9
(6,761 Views)
it is possible, of course, though there is no such algorithm in Labview and you would have to code it yourself.
K
Message 6 of 9
(6,757 Views)
Can u do one modified vi for me...?pls
Message 7 of 9
(6,753 Views)
I am sorry, I cannot do the work for you. If it was a simple piece of code, I would not mind to help a bit more. But coding such algorithm is not a trivial task. If the OpenCV based face/eyes detection in Labview does not satisfy your needs, you will need to read some papers and gradually implement the algorithm.
Best of luck.
K
Message 8 of 9
(6,750 Views)
K thank You Mr.K... I ll meet u with successive output...thanks for support...
Message 9 of 9
(6,747 Views)
