Machine Vision
finding information from an image
I want to extract information from an image . Suppose  an image containing an integer value 60 or 70 . I want  to extract the value 60 and 70 as output in integer format .can any one please help me how to get this ? And please if any one has the code then please upload it here .
Message 1 of 9
(5,069 Views)
Do you mean you want to read "60" by OCR? Can you post an image?
Message 2 of 9
(4,970 Views)
I need to find the value 50 as output from the system .Will you please help me to find this .
Message 3 of 9
(4,965 Views)
I gave up trying to teach NI's OCR and I usually use Tesseract for that, you can search the forum for ways to implements it via command line.
We have two ears and one mouth so that we can listen twice as much as we speak.
Epictetus
Antoine Chalons
Message 4 of 9
(4,943 Views)
please kindly any one help me ...and i didn't get you kindly please explain elaborately
Message 5 of 9
(4,938 Views)
sorry I don't have time to ellaborate more today, have a look at this. I'll see by the end of the week if I can dig in my old projects to show you some code.
Epictetus
Antoine Chalons
Message 6 of 9
(4,932 Views)
What are all the possible numbers? 50,60,100? Youcan convert this to binary image and extract the number alone.
Message 7 of 9
(4,931 Views)
Thank you for the suggestion ,Can you please post the vi then it will be help full
Message 8 of 9
(4,924 Views)
just look into labview examples there is example vi for this one
Message 9 of 9
(4,831 Views)
