Hi all,
I am trying to use a Firewire board (Texas Instruments, OHCI compliant) plus an AVT Marlin 033B camera with Labview. Everything worked with the AVT software, which I subsequently uninstalled again. I am using LV8.0 and Vision Acquisition Software 8.2.1. From what I understand the Firewire board should show up in MAX, and it doesn't with or without camera attached.
I am using Windows 2000 SP4, and the drivers it uses for the board are: 1394bus.sys and ohci1394.sys. These are the generic windows drivers which (from what I understand) should work with Labview. I also tried the driver supplied by AVT (intek driver), with the same result. I also looked at the troubleshooting guide for IEEE 1394 cameras, and installed the hardware/drivers in the recommended order.
Does anyone have an idea of what is going wrong?
Ralf
