Machine Vision
flir sc3000
Hi everyone,
I'm trying to assist my client to control their FLIR SC3000 Thermal Camera using PXI 1422 & LabVIEW. FLIR has a LabVIEW driver called the ThermoVision LabVIEW Digital Toolkit. I've attached the brochure for the toolkit. The problem I have is that the toolkit cannot be used to control and 'access' the high-speed option of the camera. Referring to the second page of the attached brochure, the mentions specifically that the toolkit does not support SC3000's high-speed option. The only option to take advantage of the high-speed capability of the camera is to use FLIR's Reseacher software with the High-Speed option.
To my knowledge, what the software does to 'enable' the high-speed option is by reducing the image ratio. By default, the camera captures thermal images by the size of 320x240 at 50 frames /sec (for PAL). Using the high-speed option, I can increase the frame rate up to 750 frames/sec but I have to sacrifice the image ratio down to 320x15.
With all these information, may I know if somebody has actually manage to control SC3000 along with the high-speed option using LabVIEW? or, since FLIR's LabVIEW toolkit does not give me the option to manipulate the image ratio to attain high-speed capture, is there a way to go around this?
Please advice. Thanks!
Shazlan
(5,678 Views)
Anybody?
(5,609 Views)
Hi, I'm going to use this thermocam with Labview too, but I don't have this toolkit. How did you get this? I don't know how I can get this. Can you help me with this?
Thank you.
Correa
(4,719 Views)
You can ask FLIR for the toolkit. They sell it for a price. However, you may want to ask them to try the toolkit first before committing to buying it as it may have the features that you require - which was my case last time.
Good luck!
(4,699 Views)
I will contact the FLIR to request the toolkit, but I think it is going to fit in what I'm thinking.
Thank you.
(4,694 Views)
