Machine Vision
flir sc5000
I have a Flir SC5000 research camera that I am trying to interface with a NI 1428 card. However I have had zero luck with getting any of my NI or Flir software to detect the camera over Camlink. I am able to get the Flir software to connect over an Ethernet cable and I was able to get a Camlink connection on a computer owned by a different lab using a coreco frame grabber.
So my question is: Is there a simple procedure for adding a new camera in the NI software and is my card/camera combination even supported?
Will
(5,074 Views)
Hi Will,
You need the following items to set up and use the NI 1428 ( see this link 😞
     NI 1428 image acquisition device
     Base configuration Camera Link-compatible camera
     MDR 26-pin Camera Link cable
     PCI, PXI, or Compact PCI computer running Microsoft Windows Vista/XP/2000 with at least one available slot
     NI Vision Acquisition Software 8.2.0 or later, which includes the NI-IMAQ driver software
Optional software for developing applications:
   – NI Vision Builder for Automated Inspection
   – NI Vision Development Module
   – LabVIEW
   – LabWindows™/CVI™
   – Microsoft Visual Basic
Also here is the User Manual fro the PCI-1428
Hope this get you started.Thanks and have a great day.
Esmail Hamdan | Applications Engineering | National Instruments
(5,047 Views)
Will,
Have you tried using the Camera File Generator to try configuring a new camera file for your camera? https://www.ni.com/en/support/documentation/supplemental/19/creating-a-camera-file-using-the-ni-came...
Eric
(5,039 Views)
We have all of the required hardware and software and I have created a camera file, however I now believe the issue is due to the computer being a 64 bit systems and all of the components and software being designed to run on a 32 bit system.  Thanks for your answers though.
Will
(5,009 Views)
Hi Will,
Waht is your operating system? National Instruments Visoion sould be supported for 64bit systems. See this page .
(4,994 Views)
The camera is now up and running on a 32 bit system, the other computer has Vista 64. While the camera works fine using NI software, Flir now states that NI cards are not compatable with their thermal imaging software.
(4,977 Views)
