Machine Vision
geometric matching: Difference between score and correlation score
Hi All,
What is difference between score and correlation score in geometric matching???
(4,980 Views)
Accepted by topic author JitinJ
the correlation score is based on pixel intensities where as the score of the geometric match considers also the geometry features. See the NI Vision Concepts (Geometric matching -> In-depth discussion).
Hope this helps.
K
https://decibel.ni.com/content/blogs/kl3m3n
"Kudos: Users may give one another Kudos on the forums for posts that they found particularly helpful or insightful."
(4,977 Views)
Thanx Klemen for the quick reply..
(4,961 Views)
