Machine Vision
get multiple image with PCI-1410.
sorry.  there is a mistake.
I want to get 4 images with PCI-1410.
I coded like this.
      imgInterfaceOpen("img0", &ifid);
      imgSessionOpen(ifid, &sid);
    Rect rect;
     rect.height=IMG_HEIGHT;// 640
     rect.left=0;
     rect.top=0;
     rect.width=IMG_WIDTH; // 480
  imaqSetupGrab(sid, rect);
  image = imaqGrab (sid, image, 1)  // Image *image;
In this case, I can get only one image.
so.. could you let me know, how to get 4 images ??
thanks..
(4,200 Views)
Hi James,
You might want to look at the sequence or ring examples located in C:\Documents and Settings\All Users\Documents\National Instruments\CVI\samples\IMAQ
They show how to acquire a sequence of images and perform acquisitions in a loop, extracting any buffer of the ring that you configured.
-Christophe
(4,187 Views)
Thanks Christophe.
I checked the example.
but I can't understand.  sorry..
could you tell me more detail.
I want to get 4 images from 4 different cameras with pci-1410.
please help me.
Thanks.
(4,160 Views)
I coded like this.
Init part.
 unsigned int bufSize, bufCmd;
 imgInterfaceReset(ifid);
 imgGetAttribute (sid, IMG_ATTR_ROI_WIDTH, &AcqWinWidth);
 imgGetAttribute (sid, IMG_ATTR_ROI_HEIGHT, &AcqWinHeight);
 imgGetAttribute (sid, IMG_ATTR_BYTESPERPIXEL, &bytesPerPixel);
 imgCreateBufList(NUM_RING_BUFFERS, &Bid);
 bufSize = AcqWinWidth * AcqWinHeight * bytesPerPixel;
 for (i = 0; i < NUM_RING_BUFFERS; i++)
    imgCreateBuffer(sid, IMG_HOST_FRAME, bufSize, (void**)&ImaqBuffers[i]);
    imgSetBufferElement(Bid, i, IMG_BUFF_ADDRESS, (uInt32)ImaqBuffers[i]);
    imgSetBufferElement(Bid, i, IMG_BUFF_SIZE, bufSize);
    bufCmd = (i == (NUM_RING_BUFFERS - 1)) ? IMG_CMD_LOOP : IMG_CMD_NEXT;
    imgSetBufferElement(Bid, i, IMG_BUFF_COMMAND, bufCmd);
    imgSetBufferElement(Bid, i, IMG_BUFF_CHANNEL, i);
 imgMemLock(Bid);
 imgSessionConfigure(sid, Bid);
when capture selected
 imgSessionAcquire(sid, TRUE, NULL);
 uInt32 lastAcquiredBuffer;
  void* bufferAddress = NULL;
  int    bufferIndex;
 for (bufferIndex = 0; bufferIndex < IMAGE_SIZE; bufferIndex++)
  imgGetAttribute (sid, IMG_ATTR_LAST_VALID_BUFFER, &bufferIndex);
  imgGetBufferElement (Bid, bufferIndex, IMG_BUFF_CHANNEL, &channel);
  image[bufferIndex] = MakeImage(AcqWinWidth, AcqWinHeight);
  info = GetImageInfo(image[bufferIndex]);
  memcpy(info.imageStart, ImaqBuffers[bufferIndex], AcqWinWidth*AcqWinHeight);
  DrawImage(image[bufferIndex], m_rtImage[bufferIndex]);
  imaqDisplayImage(image[bufferIndex], bufferIndex+1, 0);
 imgSessionReleaseBuffer(sid);
 imgMemUnlock(Bid);
(4,155 Views)
after testing again. I can get images from different cameras. But image is not correct. I uploaded 3 different images form my cameras. - I tested with 3 cameras. 1st images from channel 0 is always fine. but 2 other imges are always not correct. - inserted file 0_.jpg was fine one. please check this and give me the solutions. Thanks.
(4,138 Views)
