Machine Vision
get portion of one image(400*400) by size of 20*20
I wanted to get portion of one image(400*400) by size of 20*20.I have not found any function in IMAQ Vision which can resolve this problem directly.So I used ImageToArray and Array Subset,then ArrayToImage. When I wanted to filter this new image(part of primary image),one Error showed as follow.
Error -1074396154 occurred at IMAQ Convolute
The image is not large enough for the operation.
The filter kernel is 9*9. How can I resolve this problem correctly?
(3,088 Views)
icestar wrote:...I wanted to get portion of one image(400*400) by size of 20*20.I have not found any function in IMAQ Vision which can resolve this problem directly...
The IMAQ function that byou are looking for is IMAQ Extract in the Image manipulation subpalette. Do not wire the X and Y duplication steps (unless you want also to change the resolution ...) and adjust the values in the Optional Rectangle input.
Chilly Charly    (aka CC)
(3,085 Views)
Also make sure you set the border of the image large enough. I think the default is 3, and you will need 4 to process with a 9x9 kernel. I can never remember if you need to set the border correctly on the source or destination image, so I usually just set both. Another option is to change the border size after the Extract command.
Bruce
Bruce Ammons
Ammons Engineering
(3,072 Views)
