Machine Vision
help with OCR
I am doing a project where I need to do OCR on some printed lables
the font size is on 4...
and I am having a hard time seperating the letters - I am getting closer, but any hints would be highly appriciated!
ocr1 - orginal image
ocr3 - incresed brightness and contrasts
ocr4 - converted to binary, and used erode
(6,571 Views)
Try Gray Morphology - Dilate followed by Threshold.  To separate characters you need to be able to draw a straight line vertically between characters without touching anything (blank space).  You need to have at least one-pixel between characters.  See attached image and example.
Matthew Fitzsimons
Certified LabVIEW Architect
LabVIEW 6.1 ... 2013, LVOOP, GOOP, TestStand, DAQ, and Vison
(6,556 Views)
Thanks a lot, will try this tomorrow
Why dialate and not erode?
(6,548 Views)
Yes, seems to work in reverse of what you would think.  Play with both and you will see why I chose dilate.
Matt
Matthew Fitzsimons
(6,546 Views)
I will 🙂
And I was not aware that a straight horizontal line was needed to separate the letters, that explains a lot!
(6,542 Views)
Meant Vertical line of course ...
(6,538 Views)
That is why you get to enter a security phrase when you buy tickets to prevent OCR automated buying.
Matthew Fitzsimons
(6,537 Views)
