Machine Vision
how can I access the "vision info" in an image
Development Environment:
  • LabVIEW 2012 32-bit (12.0f3)
  • Vision 2012
Description:
I would like to get more information regarding the "vision info" in an image.
There is a VI called IMAQ Is Vision Info Present 2 - which tells me whether any vision info is present in the image.
But then what can I use to read or access this vision info, aside from using IMAQ Read Custom Data - or is this all there is?
ie.  I have created a template in Vision Assistant using the Template editor and highlighted some mask areas - how can I open this up in LabVIEW and get this information?
The Vision help files don't seem to define this to a low level of detail.
Thanks!
Christopher Farmer
Certified LabVIEW Architect and LabVIEW Champion
DQMH Trusted Advisor
https://wiredinsoftware.com.au
Message 1 of 10
(5,866 Views)
Hello Christopher,
The best solution that I have found so far would be to use the IMAQ Get Custom Keys VI to peel off an array of all the Keys for the image and then spin that through a for loop pulling out all the information with a IMAQ Read Custom Data VI, unless you know which Keys you are looking for.
Cheers,
Joel
Message 2 of 10
(5,844 Views)
Hi Joel,
I tried that technique, however it only gives me two items in the array: NI Image Type and Version.
What I need to get to is the Geometric Template 2 information. My template file was created using the NI Template Editor.
IMAQ Is Vision Info Present 2 tells me the geometric template information is there. How can I access this?
Christopher Farmer
Message 3 of 10
(5,807 Views)
Accepted by topic author ChrisFarmerWIS
Hi Christopher,
Have you tried our IMAQ Get Geometric Template features VI? Information on this VI can be found here: http://zone.ni.com/reference/en-XX/help/370281P-01/imaqvision/imaq_get_geometric_template_features/
This VI will allow you to reference your created template image and returns the features of that image giving the ‘Feature Type’ and the associated data with that feature. This should allow you to access the data you need.
Blake C.
www.ni.com/support
Message 4 of 10
(5,782 Views)
Hi Blake,
Yes, I saw that - I will take a closer look . Thanks.
So can we extract the curve parameters cluster back out (that were defined by the template editor)?
Christopher Farmer
Message 5 of 10
(5,769 Views)
Yes, you should be able to. You can see that data under ‘Feature Data’ on the ‘Learned Features’ output on the help page I linked. It gives you Elements 0-4 of the constant curve.
Blake C.
www.ni.com/support
Message 6 of 10
(5,748 Views)
Curve settings of geometric template.PNGbut how to get the curve settings of the geometric template ?
Message 7 of 10
(5,570 Views)
Standy,
It does not appear that there is a method to extract those settings from the template editor.  It appears those settings are meant to be set in the editor and left alone once the template is in use.
Isaac Sanchez
Applications Engineering
Isaac S.
Message 8 of 10
(5,547 Views)
Hi Isaac,
My mean is that when I have configed the curve paramters in template editor for the geometric template. the editor will save the template info with the template image together. but when I open the template image in another APP, I want to read the template info ( or vision info) back.
I have test that the NI VISION ASSISTANT can read back the template info of the geometric template which had been edited by the template editor. but I don't know how to do this in my vision application.
thanks very much for your help.
Best Regards
Standy.
Message 9 of 10
(5,538 Views)
Hi Standy
    i meet this problem, so i really want to know how do you solve this problem finally.
this may be a long time, so i don't know whether can i  hear from you.
thanks
warm regards
wenjie zheng
 AE China
Message 10 of 10
(4,588 Views)
