Machine Vision
how can be used a non Direct Show camera in Vision Assistant 8.5?
Dear Brad and Jaidev,
There is a file called qdv.dll in System32 which is a decoder for DV format.
It is written by microsoft for converting DV into PAL in 720 X 576 resolution.
Is there any way to decode this file in 'C' and rewrite again the pixel resolution with the help of Labview Pro 8.5.
Regards
Sandesh
Message 11 of 12
(1,066 Views)
Hi Sandesh,
Unfortunately, it is not possible to reconstruct C code from a dll. A dll is a binary image that gets loaded into system memory. Doesnt Microsoft already have functions in Directshow to do this? http://msdn.microsoft.com/en-us/library/ms783495(VS.85).aspx
It might be possible (need clarification) to make directshow calls in LabVIEW but if you have no experience with COM programming, I would not recommed it.
Thank you,
Jaidev
Senior Product Manager
Message 12 of 12
(1,049 Views)
