Machine Vision
how can i add a speckle noise to image
hi;
i am new in inage processing in LabVIEW , please how can i add a speckle noise to an image ???
i added a Gaussian noise by using signal processing tools , but there is no speckle noise in this tools.
help me pls
(5,704 Views)
Hi Sara,
Unfortunately, at this time, NI Vision does not have the capability to add speckle noise to an image.  There were a few hits about resolving it:
http://forums.ni.com/ni/board/message?board.id=200&message.id=22031&requireLogin=False
http://decibel.ni.com/content/docs/DOC-1746
http://zone.ni.com/devzone/cda/tut/p/id/3472
but none about generation.  I recommend creating an idea in the NI idea exchange for this.
Cheers
Marti C
NI Medical
(5,678 Views)
thanx Marti
I try to use a LabVIEW MathScrip instead.
(5,669 Views)
Can you define speckle noise?  Is that just white pixels randomly distributed?  Black pixels also?  Full black/white or related to pixel's original value?
If I know exactly what you are trying to generate, I can probably suggest a simple algorithm to get it.
Bruce
Bruce Ammons
Ammons Engineering
(5,650 Views)
speckle noise is a multiplicative noise , i.e this noise is multiplied by the orginal image
according to the gamma distribution, ithink its so dificult to suggest algorithm to do that,
in Matlab there is a function used to this purpose
(5,629 Views)
