Machine Vision
how can i save transparent image
I would like to save an image with transparent but it only shows a grey background. It looks like all image information are lost when I rebuilt
the image out of the array (IMAG array to image.vi).
For clarification I attached the vi.
Thanks for the help!
(4,667 Views)
Does anybody knows why I can not save the changed image?
(4,632 Views)
Hmm... There are many reasons why you can't do it in such way:
(4,626 Views)
Accepted by topic author Norick_17
If you need to store "transparent" image into file and load it back without parsing, then you can use the fact that overlay can be saved in PNG file with vision info.
Something like that:
Result will be:
Andrey.
(4,625 Views)
Hi Andrey
thank you very much for your explinations! This solution is exactly what I have been looking for...
best regards
                 Norick
(4,604 Views)
Can you please attach this VI in an older labview version (8.6). Thank you!
(4,313 Views)
