Machine Vision
how do I access the elements of the StraightEdgeReport?
I'm trying to access the elements of a variable of type StraightEdgeReport*. in IMAQ vision with VC++ 6.0 like this: Edge = imaqFindEdge(procSearchImg, patternRect, endEdgeDir, &edgeOptions, NULL);
float startX = Edge.start.x;
But I get compiler error error C2228: left of '.start' must have class/struct/union type
I know that the imaqFindEdge worked correctly in debug mode. I am kind of new at programming so I need some help on this. Thanks.
(2,898 Views)
This issue was troubleshooted with National Instruments over the phone and it was discovered that the problem was the syntax. The correct syntax is
edge[0].element
instead of edge.element
Regards
Russell Blake
Applications Engineering
Director of Engineering
G Systems, www.gsystems.com
Certified LabVIEW Architect
Certified LabVIEW Embedded Systems Developer
GCentral
(2,898 Views)
