Chuck,
All of the options I have ever seen for changing the exposure time and using integration all depend on the camera. Once the camera has digitized the image and sent it to the computer, there is no way to do the integration.
One possibility is to acquire multiple images in a sequence, then add them together to get a single brighter image. Essentially, you are integrating the images.
Another possibility is to use binning to trade resolution for brightness. If you combine 2x2 blocks of pixels into single pixels, the resulting pixels will be 4x as bright. Unfortunately, this method reduces your resolution in half.
Perhaps another solution would be to use a brighter light for illuminating your target. There are some very high intensity lights fo
r small areas available.
Bruce
Bruce Ammons
Ammons Engineering
