Machine Vision
how do i load a new set of images into golden template VI provided in the examples
Message 1 of 28
(4,967 Views)
Which example are you talking about? Do you want to read the image from a folder or camera? Did you try placing the file open in the beginning?
Message 2 of 28
(4,962 Views)
the example is golden template inspection.vi
i want to read the images from a different folder..
Message 3 of 28
(4,958 Views)
Message 4 of 28
(4,939 Views)
This vi will return the path where you have saved your current vi. The example uses this path for both the template and the image. The differentiation is done in the list folder and strip path where it is specified jpg and png respectively. Just delete the abave vi (current vi's path) replace it with your folder name. Also make sure the images that you are feeding are jpg else change the image format accordingly.
Message 5 of 28
(4,938 Views)
thank you.. now, how can i find a match for my image by adjusting threshold from the same folder of images??
Message 6 of 28
(4,936 Views)
By applying threshold you will be converting it into a binary image. Do you want to go for shape detection?
Message 7 of 28
(4,929 Views)
its not shape detection.... its just pattern matching... i'm trying to subtract reference image from the images in the folder and thus to find a perfect match...
Message 8 of 28
(4,927 Views)
Then why thresolding? Play around with vision assistant. Generate a vi from vision assistant and check for repeatability and consistency. You can always modify it in labVIEW later.
Message 9 of 28
(4,925 Views)
i was trying to use the golden template inspection.vi available in the examples for various other images..
i just want to modify the VI such that it can be implemented to find the perfect match from a group of images and display that...
Message 10 of 28
(4,924 Views)
