Machine Vision
how do i load a new set of images into golden template VI provided in the examples
balakrishnan wrote:
i was trying to use the golden template inspection.vi available in the examples for various other images..
i just want to modify the VI such that it can be implemented to find the perfect match from a group of images and display that...
I will strongly suggest you totry the template match on your own. Take the example to understand how it is done. Do it yourself and post back if you are stuck.
Message 11 of 28
(2,151 Views)
i've already created the templates for matching.... the problem is that, a match is not being found... i'm not able to understand as of where i have gone wrong.. i wil send u the VI...
Message 12 of 28
(2,150 Views)
I dont have lv 2009. Can you attach it for 8.0 or attach a screen shot?
Message 13 of 28
(2,144 Views)
i'm attaching the vi in 8.0
Message 14 of 28
(2,138 Views)
did u get the attached file????
Message 15 of 28
(2,120 Views)
hey, could you help me to find out the threshold values in the VI i had sent you last day??
so that it can find out the perfect  match from the lot...
Message 16 of 28
(2,088 Views)
Yeah i got it. Lemme go through it and get back.
Message 17 of 28
(2,057 Views)
Message Edited by balakrishnan on 01-12-2010 11:29 PM
Message 18 of 28
(2,056 Views)
i want to create a VI which can hold many reference images at a time and compare it with the incoming image and display the match found.. how can i go about this??
i tried golden template inspection VI after editing it, and its not working...
By using COMPARE TWO PATHS.VI, can i hold many images as reference???
Message 19 of 28
(2,053 Views)
hey, i will send you a new VI which i created... pls help me to find the match in this VI.
Message 20 of 28
(2,039 Views)
