Machine Vision
how do i match a pattern and extract it from an image
Using IMAQ for Labview.
I need to match a pattern in an image, and then either crop the image such that all that is left is the area of the pattern, or extract the area of the pattern and save it to a new image file. I am struggling to convert the "pattern match" data into data which may be used to describe a ROI to extract the area of interest
Mike
(3,325 Views)
Mike. I've created a quick VI that may do want you want. The only problem arises when a pattern is rotated and you try to extract it. Since you can't build an image that isn't rectangular, I had to extract the rectangle that surrounds the pattern.
Please let me know if you have any other questions.
Kyle V
www.ni.com/ask
(3,325 Views)
Perfect.
Cheers,
Mike
(3,325 Views)
