Machine Vision
how do i pass an imaq sequence into Matlab?
I would like to be able to pass an Imaq seqence (128x128 x 1500 frames x 2 bytes/pixel) directly into Matlab for processing.  I am currently saving the image sequence to an array (imaq image to array vi), saving the array and then opening it in matlab.  this process is painfuly slow and save a lot of unneccesary data - the matlab code generates and saves a processed subset of the data.
(5,463 Views)
 Hey Jwock,
You can use the "Image Acquisition Toolbox"
which is a Matlab's tool that allows you to acquire images and video from cameras and frame grabbers directly into MATLAB and Simulink. You can detect hardware automatically and configure hardware properties.
I leave you a reference here for you to check it out:
"Image Acquisition Toolbox Documentation"
http://www.mathworks.com/help/imaq/index.html
Hope that helps to adress you in the right direction.
Regards!
Daniel C.
(5,408 Views)
Daniel,
Thanks for the reply.  I am using the IMAQ toolbox to setpup my camera and acquire data.  That's not the problem.  My data is a contiguous sequence of >1000 frames, which I can acquire using the various tools in that toolbox.  I want to pass the data into Matlab, which is superior for the image processing I need to perform.  In order to do that, I am writing and saving the image data to a pre-allocated Labview 3D array and then opening the file in a Matlab script window, which is both cumbersome and slow.  The Matlab script interface only allows me to pass 2D real arrays, but my data is 3D.
-S
(5,402 Views)
Sorry, I should have added that I am stuck using hte Labview acquisition environment.
(5,401 Views)
I'd convert each image to a 1D array (instead of 2D) and then make your 2D array from that. Then in Matlab you can reshape each array back to a 2D one based on the known dimensions. This is certainly much more efficient than using a file.
(5,395 Views)
that's a good idea as a work-around but there has to be a better way to do this. i will continue to bang my head against it as time permits and post whatever solution i come up with.  i don't believe i am the only one with this issue.
(5,388 Views)
Accepted by topic author jwock
Figured it out...turns out that Matlab remains persistent in the Labview environment once it's been called so a simple Labview loop on the number of frames does the trick nicely...
(5,322 Views)
