Machine Vision
how do you mask pixels outside a region of interest
I am using Labview to perform some eye tracking, I am particularly looking at some reflections in the pupil.  I use a circular edge VI to find the pupil.  I then use the pupil parameters to construct a region of interest.  After this I use a ROI to Image mask VI then a IMAQ Mask VI to attempt to isolate the pupil.  The problem is the mask replaces all the pixels inside the region of interest rather than outside it.  How do I go about getting it to mask the pixels outside the pupil rather than inside?
Any help would be greatly appreciated.
Joe
(5,096 Views)
Hi, Joe,
Just try to inverse your Mask with IMAQ Inverse.
Andrey.
(5,095 Views)
The default value is to mask outside only. You can do like this
(5,081 Views)
solved?
(5,045 Views)
Yes thank you I found another example describing how to find a circular region of interest which worked, unfortunatley I don't seem to have the VI you were refering to.  This was the solution I used in the end.
(5,043 Views)
The function which i pasted was created from vision assistant. You will have IVA lib files too. Anyway glad you have a solution...:smileywink:
(5,041 Views)
