Machine Vision
how does threshold level in edge detection effects an image after it has been thresholded using the manual threshold function?
I am trying to use edge detection in my applicaton.
case1)
I load the image(8 bit) and apply Edge detection using Simple edge with level type:Absolute and I specify the threshold level. Now depending on the threshold level, the positions of the edges detected varies.That is perfectly fine.
case2)Before using the edge detector, I use manual threshold with threshold levels Min=128 and Max=255. After applying, the image is converted into a binary image. Now if I go ahead and apply the edge detection tool,It picks the edge at the point where the background(black) changes to white( binary value 1).
Now if in edge detection tool I try to specify t
he threshold level again, say 230 how is the edge located. As far as my understanding goes, since the pic we are looking at is a binary one the threshold level shouldn't matter now. It would pick the edge depending on whether the pixel value is 0 or 1.
I have personally observed that when I change the threshold level in the edge detection , the position of the edge seems to shift slightly even though the image is a binary one.
(3,083 Views)
Make sure you are using the advanced edge detection tool. This will allow you to select the parameters for finding an edge. Reduce the contrat to 1, and the steepness and filter width to 0. Refer to our Vision Concepts Manual Ch 11 for futher information on edge detection and how the parameters effect performance.
http://www.ni.com/pdf/manuals/322916a.pdf
I hope this helps!
Chris D
NI Applications Engineer
(3,083 Views)
