Machine Vision
how to acquire several pictures with vision assistant?
Hi!
I would like to know how acquire picture with vision assitant but not only one picture. I would like to do like in vision builder. I want do a program with wich I can treat
a picture and after an other without doing something.
thanks
(2,957 Views)
Once you developed your algorithm in Vision Assistant, you can run it on new acquired images by using the Batch Processing function (Tools>>Batch Processing). This mode allows to apply the algorithm you prototype to all the images in the browser, or from an image acquired with your framegrabber. You can save the resulting images in the folder of your choice.
Hope this helps.
-Christophe Caltagirone
IMAQ R&D
(2,942 Views)
