Machine Vision
how to combine vision assistant and motion assistant
how do i connect movement of motors using vision assistant and motion assistant. can i combine the working of the two? if i can then how?
(3,258 Views)
Both assistant can migrate their script to LabVIEW. Vision Assistant can also be invoked from an Express VI inside of LabVIEW. So you can use LabVIEW to combine the solution that you would have prototyped using the assistant.
Vision Assistant also features a Run LabVIEW step, that you can use to import the code generated by Motion Assistant.
-Christophe
(3,245 Views)
Hijacking this; have you found a solution?
I would need the xml-Files generated when using "Create LabVIEW-Code" in Motion Assistant..
Birgit
(3,224 Views)
