Machine Vision
how to convolute an image with low pass filter?
I need to convolute a whole image by using a low pass filter. I know there is a low pass filter vi but it looks like it is applied to an image one shot but not "convolute" the image. Does anyone have an idea of doing this?
thz
(3,793 Views)
Use the IMAQ convolution vi.  The icon is a circle with an X in it.  It is in the same palette as the low pass filter.  You need to provide the matrix input for the convolution and the images.
Bruce
Bruce Ammons
Ammons Engineering
(3,787 Views)
Hi Liaw,
Bruce is correct, and the matrix input he referred to is called a Kernel.  Many useful kernels are outlined in the IMAQ Vision Concepts Manual.
Good luck on your application,
Robert
(3,781 Views)
I knew convolute vi can be used. However, what is the input matrix of kernel that has property of low pass filter? In other words, I need to convolute an image with low pass filter's kernel...
thx..
(3,775 Views)
Two examples of a smoothing kernel are:
0  1  0           2  2  2
1  0  1           2  1  2
0  1  0           2  2  2
The topic of kernels is covered both in the Vision Concepts Manual and many image processing textbooks.
Hope this helps!
Robert
(3,770 Views)
