Machine Vision
how to set dynamic roi for character recognition using OCR
how to Set dynamic ROI for reading characters in image captured from camera.
(3,758 Views)
You are kind of requesting to put the cart before the horse.  You have to set the ROI large enough so that you can find any instance of a character you are expecting, although if you know how the size will change under different circumstances, you can certainly adjust the size of the ROI dynamically.  To do this, I typically use the IMAQ Convert Rectangle to ROI, and change the rectangle bounds as needed.
(3,593 Views)
